It is currently Sun Aug 03, 2025 12:59 am
PostPosted: Mon Nov 17, 2008 11:34 am
I want to minimize shredding of my tops when cutting with the bandsaw. Rockler told me that I need to have 3 teeth in the wood which would mean a very fine blade with 18 or more teeth to the inch. I was planning on getting a 1/4" blade with 8 to 10 tpi? What works best for you?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Mon Nov 17, 2008 11:53 am
1/4" x 10 works just fine. I'm sure an 8 would work too.
PostPosted: Mon Nov 17, 2008 12:42 pm
I just cut four out (2 backs, 2 tops) with a 1/4" - 10, works just fine.
PostPosted: Mon Nov 17, 2008 1:27 pm
I use a 1/4 x 6tpi for about everything that needs a curved cut. It matters at least as much to avoiding tearout to use a zero clearance insert.
PostPosted: Mon Nov 17, 2008 2:25 pm
Same here!.
PostPosted: Mon Nov 17, 2008 5:03 pm
Using a 1/4" 6tpi blade here as well......
PostPosted: Mon Nov 17, 2008 6:13 pm
1/4" 10tpi
Formerly JJH
PostPosted: Mon Nov 17, 2008 7:57 pm
I went with the 1/4" 10 tpi. Cuts with no shredding. I do seem to have a problem with my upper pully on my 14" Jet. Its got a wobble in it. Anybody run across this problem. I think a steel replacement would be better than the aluminum one. I see that it has some hairline cracks radiating from the center.
Rich Smith
Issaquah, WA
PostPosted: Tue Nov 18, 2008 8:20 am
Just to be different I use a 3/16-10 tpi ... for the life of me I cant get a 1/4-6 to run all that well. I can change from 1/2-3 to 3/16-10 and all I need to do is adjust the roller guides. Those are all I buy.
Users browsing this forum: meddlingfool and 21 guests
